There's been much talk on other Q&A threads on how to connect decoupling capacitors to an IC, resulting in two completely opposite approaches to the problem:
- (a) Place decoupling capacitors as close as possible to the IC power pins.
- (b) Connect the IC power pins as close as possible to the power planes, then place the decoupling capacitors as close as possible, but respecting the vias.
According to [Kraig Mitzner], option (a) is preferable for analog ICs. I see the logic behind it, as the inductance of the via and the decoupling capacitor form a low pass LC filter that keeps noise away from the IC's pins. But according to [Todd H. Hubbing], option (a):
[...] sounds like a good idea until you apply some realistic numbers and evaluate the tradeoffs. In general, any approach that adds more inductance (without adding more loss) is a bad idea. Power and ground pins of an active device should generally be connected directly to the power planes.
As for option (b), [Kraig Mitzner] (the author of the above figure) says that it is preferable for digital circuits, but he does not explain why. I understand that in option (b) the inductive loops are kept as small as possible; but still, they allow switching noise from the IC to get quite easily into the power planes, which is what I want to avoid.
Are these recommendations correct? What exact reasoning are they based on?
EDIT: consider that the via from the IC leads to the capacitor and vias are kept as short as possible. They are shown in the figure as long traces only for illustration purposes.
