I'm currently reading an article (in Russian) and the author compares two devices (hard disks) of the same model one manufactured by Company A and the other manufactured by Company B. One of the things he compares is how solder looks like on the boards.
Company A device board has soldered parts looking like this:
and this is claimed to be "low quality tin-coating". What I see is that solder spots are not shiny and the solder layer is thinner near the spot edges and thicker far from the edges (a bit concave).
Company B device has soldered parts looking like this (that's exactly the same area of the board as on the Company A device):
and this is claimed to be "high quality tin-coating". What I see is that solder spots look shiny and the solder layer looks having uniform thickness across each spot.
So to me the first board just looks neater. From what I know about soldering once the surfaces have been properly degreased with soldering flux and the solder was melted properly the connection will be just fine regardless of how shiny and neat looking it is.
However the author claims that the Company B device is of higher quality and should be preferred because of (among other factors) the "better quality" of tin-coating. How reasonable is such claim? Can device reliability be judged based on such tin-coating analysis?
