I have a question regarding scheduler implementation. I have tried to implement a scheduler according to my understanding.
In this example, i have taken advantage of the Systick handler provided by STM32, so my handler looks somewhat like this:
void SysTick_Handler(void)
  HAL_IncTick();
  HAL_SYSTICK_IRQHandler();
  if(ticks_for_scheduler++==100)
      ticks_for_scheduler=0;
I have a scheduler.h file which looks like this:
void (*task1)() = read_temp;
void (*task2)() = Display_temp_lcd;
and my scheduler.c looks like this:
extern uint16_t ticks_for_scheduler;
void sched_system()
  if(ticks_for_scheduler==20)
      (*task1)();
  if(ticks_for_scheduler==40)
      (*task2)();
The function sched_system is called in main(){while(1){sched_system();}My goal is to execute task1 every 20ms, and task2 every 40ms, but somehow I'm not able to get it right. I'm not sure what I'm doing wrong? I don't see the results on my LCD as expected.
    \$\begingroup\$ ticks_for_schedulerneeds to be declared volatile. \$\endgroup\$
    – brhans
    Commented Oct 8, 2017 at 15:21
Your ticks_for_scheduler variable simply counts from 0-99 over and over again, one count per millisecond. This means that it contains any particular value once every 100 ms.
In your main function, that's all you're checking for — whether the variable contains a particular value. So each task will only execute once every 100 ms.
In the most general case, where any given task needs to execute every N ms, you need to maintain a separate counter for each task. In the more constrained case in which every period N has a common multiple of 100 ms, you can use a modulo operator:
if (ticks_for_scheduler%20 == 0) (*task1)();
if (ticks_for_scheduler%25 == 0) (*task2)();
Note that 40 ms does not have 100 ms as a multiple, but you could make the ticks_for_scheduler run from 0-199 if you want to use 40 ms as an interval.
There's a more subtle problem here, too. You're assuming that sched_system() runs at least every 1 ms, so that it can "see" every possible value of ticks_for_scheduler. But if any given task runs for longer than 1 ms, this cannot be guaranteed. You need to take precautions that the operation of your scheduler cannot be perturbed by the tasks themselves, which is a topic far too broad to address here.
  • \$\begingroup\$ The systick is configured to generate an interrupt every 1ms, i checked it.I would need an oscilloscope to check if it is exactly 1ms. :)O my, you're right i can't make sure that one task takes longer than 1 ms. I guess i need to redesign the whole thing. Thanks! \$\endgroup\$
    – Abel Tom
    Commented Oct 8, 2017 at 16:39
