Sometime ago, I came across some theory saying that in a control loop any transfer functions
such as input/output impedance, voltage gain
can be derived from loop gain. Maybe something like any transfer function related to loop gain will have the denominator in the form (1+T)
with T
is loop gain. However, I couldn't find it now.
Hope anyone here can help with some material or name of the theory.
\$\begingroup\$ Your guess is right. Take a look at: electronics-tutorials.ws/systems/closed-loop-system.html There they explain loop control is a straigth forward way \$\endgroup\$– DecapodOct 10, 2017 at 7:24
1 Answer
Actually, in a system featuring a unity return as shown below, the perturbation \$u_1\$ is rejected by an amount depending on \$S=\frac{1}{1+T(s)}\$. \$S\$ is the sensitivity function and it shows how robust the system is to incoming perturbations. You can see that if you have a large open-loop gain in dc, for \$s=0\$, then \$S\$ is close to 0 and the rejection is perfect. As the magnitude of \$T\$ reduces when frequency increases and you approach crossover (the 0-dB point), the system is less and less at ease to reject these disturbances. When you pass the 0-dB point, the system runs in open-loop ac-wise and does what it can to react: no gain, no control system.
Classical perturbations are the input voltage \$V_{in}\$ and the output current \$I_{out}\$. The rejection of \$V_{in}\$ is called the audio-susceptibility of the considered equipment, also called input line rejection. It is the capability of a converter, for instance, to maintain a perfectly-regulated \$V_{out}\$ despite input voltage variations. If you consider \$A_{S,OL}\$ as the open-loop audio susceptibility of a given control system operated in open-loop, then once you close the loop, the new audio susceptibility becomes: \$A_{S,CL}=\frac{A_{S,OL}}{1+T(s)}\$.
For the output current, the small-signal open-loop output voltage variations are linked to the output impedance: \$\Delta V_{out}=Z_{out,OL}\times \Delta I_{out}\$. When you close the loop, the new output impedance becomes: \$Z_{out,CL}=\frac{Z_{out,OL}}{1+T(s)}\$. You may find more information in this PPT.
