This is my first layout connecting two BGAs: DDR3 SDRAM and a Zynq SoC. The design has 4 layers and I'm using Kicad. So far I've understood the following:
1. Focus on signal groups, i.e. ADDR, CTRL, CMD and data bytes.
2. Use the same layer transitions (VIAs) in each group for convenient length/delay control.
General things I keep in mind is to have the traces somewhat short (~25 mm). Looking at various tutorials this seems to be a trivial matter for experienced PCB designers. I do this so that I don't have to worry too much about impedance control.
Starting with the ADDR pins, I have ended up with the layout below. This is perhaps my 5th attempt as I've started over multiple times. ADDR pin traces layed out
To my not so experienced eyes, this seems like a complete chaos and I have many more pin connections to go. On top of this, all traces will have to be length matched which will introduce even more challenges.
My humble question is: can someone give me a few tips on how to proceed with this?
Is layer increasing the way to go? And/or a larger distance between the components?
To me it seems like Xilinx could've picked better locations for their DDR3 pins in order to simplify the layout work.
Components:
DDR3 SDRAM datasheet - IS43TR16640B-125JBLI
Zynq-7000 Pkg Pinout specs - XC7Z010CLG400
You may wan't to route those signals with a controlled impedance, which makes it almost mandatory to have an uninterrupted plane on an adjacent layer. Xilinx suggests IIRC 40 Ohm routing impedance for DDR3 on Zynq, which will create fairly wide traces if you are not using very thin laminates.
Concerning the pin-out on the CLG400 package you are right, it's quite a pain for DDR3 routing, especially when comparing with SoC optimized for low-cost 4-layer boards.
You may also want to check if you can route two tracks on the outer layer between two BGA balls. With the 0.8mm pitch, this leaves you with something like 0.3-0.4mm pad diameter and 0.08-0.1mm track/space. Something which probably not every PCB manufacturer will do.
I suggest you to have a look on the layout of the MicroZED to get some inspiration.
  • \$\begingroup\$ Thanks! I was just told by a few that I shouldn't bother with impedance control when the traces are relatively short (less than 2 inches). As I'm new to this it's hard to navigate the non-consistent advice given here and there. \$\endgroup\$
    – toxUP
    Oct 10, 2017 at 9:24
    \$\begingroup\$ If you want to consider your traces as electrically short and therefore not bother with impedance control, the typical rule of thumb is that the propagation delay td should be no more tr/10. With rise times in the range of 200 ps, you can consider a delay of 20 ps electrically short, which equals to 150mm/ns * 0.020ns = 3mm. So "less than 2 inches" may be true for much slower rise times around 3 ns. \$\endgroup\$
    – Manu3l0us
    Oct 10, 2017 at 12:36
  • \$\begingroup\$ Damn. Makes sense to me. My good ol' University electronics book even states tr/20. Thanks for elaborating. \$\endgroup\$
    – toxUP
    Oct 11, 2017 at 1:08
