I'm powering (hoping to power?) two boards from one 12V AC source. One is a preamp requiring 12V AC in (easy so far) and the other is a scavenged audio board requiring +12/-15V DC.
I'm using the circuit below to double + rectify the AC into ±18VDC, then into a 7812 and 7915 which measure the expected +12/-15V at output.
The preamp powers up fine, and the audio board powers up fine, but when I connect them via the audio board's audio output, I get sparks and smoke.
Any ideas? Is it because I'm using the AC leg as ground for the DC circuit, and so the DC voltages are fluctuating with ground but staying the same 'distance' from ground, so they meter correctly?
