I'm attempting to set up Keil uVision to build a simple C++ program for the STM32F3 microcontroller. I've downloaded the GNU ARM toolchain on my Windows computer and placed it into the directory C:\Program Files (x86)\GNU Tools ARM Embedded\bin\. In Keil, I created a project and opened a window Manage Project Items where I was able to select Use GCC Compiler (GNU) for ARM projects and specified the prefix arm-none-eabi-.
When I click Build, the output window shows that it finishes compiling and reaches the linking stage. Here's the output:
Rebuild target 'Target 1' linking... --- Error: failed to execute 'arm-none-eabi-gcc' ".\evt-bms.elf" - 1 Error(s), 0 Warning(s). Target not created. Build Time Elapsed: 00:00:00
I've verified that arm-none-eabi-gcc.exe is in the bin directory (though I'd be expecting a complaint about g++ since it's a C++ source).
Here's a screenshot of the Folders/Extensions settings page: Folders/Extensions settings screenshot
Does anyone have any ideas for further debugging I can do? It'd be great if the output window had a little more information, as it really isn't all that helpful by just saying it couldn't run it without any context of the command it attempted.
  • \$\begingroup\$ C++ code needs to be linked with the …-g++ compiler driver, because the linker cannot tell from the .o files that these used to be C++, so linking with …-gcc will not link correctly. There should be a setting somewhere to select how to call the linker, but I don't have a current installation, so I cannot check. \$\endgroup\$ Oct 14, 2017 at 2:15
    \$\begingroup\$ Try running the identical command line from a terminal, to see what the compiler says directly. (You can add -v or --verbose for more information) \$\endgroup\$
    – user16324
    Oct 14, 2017 at 10:53
  • \$\begingroup\$ @BrianDrummond unfortunately I can't even see what command was run that triggered that. The output I posted was the result of clicking the Build or Rebuild buttons. \$\endgroup\$ Oct 15, 2017 at 13:32
    \$\begingroup\$ There will be some way to get that command line - buried deep in the documentation, no doubt. \$\endgroup\$
    – user16324
    Oct 15, 2017 at 20:41
I use Keil µVision, too (didn't even know you can set the GNU compiler)
I installed the "GNU Tools ARM Embedded\6 2017-q2-update" and Keil automatically filled the path - but without the leading /bin/ as seen in your screenshot. Maybe try removing it? (e.g. my path is "C:\Program Files (x86)\GNU Tools ARM Embedded\6 2017-q2-update\")
