I'm working on a simple audio circuit which takes two different signals from mp3 players (earphones output), mix them up and outputs to an amplifier/speaker. But before mixing the signals, I need to measure the onset of Signal 1 with a microcontroller, in the case an Atmega328. I have little experience with audio and amplifiers so I don't know how to split Signal 1 from Signal 2 in order to read Signal 1 only.
I have also added a simple voltage divider for DC offset so the Atmega328 won't read negative voltages. Below a simple schematic of what I have so far:
  • \$\begingroup\$ "I need to measure the onset of Signal 1 with a microcontroller", why? - Also, have you tried this circuit already? Connecting the two outputs of the mp3 players without any resistor between them? \$\endgroup\$ Oct 15, 2017 at 11:17
  • \$\begingroup\$ This is for an artwork, one of the sounds playing will trigger lights, the other is background but both need to be coming out from the same speaker. I tried, it outputs the sound fine. The only issue is what to do to read just signal 1... \$\endgroup\$
    – Emerson
    Oct 15, 2017 at 11:20
  • Put 1 kΩ between signal 1 and audio in
  • Put 1 kΩ between signal 2 and audio in
  • Disconnect \$C_1\$ from audio in
  • Connect a wire from signal 1 to \$C_1\$
In theory you'll get 100% of signal 1 onto A0 of the Arduino. In reality you're probably going to get 99.9%, 0.01% being random noise and signal 2. I hope you can live with that.
  • \$\begingroup\$ That's great, I don't mind if it's 100%, this will be enough for the threshold I need. I will try it today and vote for the solution later on. Thank you! \$\endgroup\$
    – Emerson
    Oct 15, 2017 at 11:38
