I did insert in schematic the LD1117 V3.3, from Sparkun library. I need to convert 5V to 3v3.
Device selected is V_REG_LD1117VXX, package 78XXL.
I want use it for LM1117v33 (or LD1117V33). This is the datasheet:
https://www.sparkfun.com/datasheets/Components/LD1117V33.pdf
When I did switch to board, seems to me that PINOUT is inverted (from Left to Right I red IN/GND , GND/3.3V and OUT/5V) and also the names on it are wrong.
I attach an imagine (small and larger). Where am I wrong? Thank you very much.
