Trying to understand how voltage \$ V_{D1} \$ is found.
Here's the original circuit with solution:
Here's how I think it can be redrawn, basically the grounds are just one node:
So to find voltage \$ V_{d1} \$ one first considers what's voltage at point 1, positive side of \$V_{d1}\$ right?
Well, at point 1, voltage is what? \$ -10K \times 1.33mA? \$
How about voltage across 5k resistor? Point 1 is between 10k and 5k resistors...
For point 2 it's 0, since the node of that point is connected to ground, right?
  • \$\begingroup\$ Here's a similar, simpler question, i.imgur.com/yV5EAyX.jpg. Basically, what's the voltage at point 1? Is it: (current through R1) times R1 + (current through R2) times R2??? \$\endgroup\$
    – Jack
    Oct 17, 2017 at 1:52
For \$V_{D1}\$ you can consider two KVL loops—they should both give you the same answer.
At point 1, you could start from the leftmost source (start from the ground) and say:
$$ \text{10V}-i_{D2}(10\text{k})-V_{D1}=0$$
You already have the current then solving for \$V_{D1}\$ results in \$V_{D1}=-3.3\text{V}\$
You may also use another KVL loop:
$$ V_{D1}-i_{D2}(5\text{k})-(-10\text{V})=0$$
And solving for \$V_{D1}\$ will result in the same.
