I just received an Arduino ATmega2560 (GEEKCREIT). The 5V interface is giving exactly 5V as expected.
But on the 3.3V interface I could only measure 0.23V. What could be wrong?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI just received an Arduino ATmega2560 (GEEKCREIT). The 5V interface is giving exactly 5V as expected.
The first thing to verify is the 3v3 regulator, you could start measuring voltages at the IC6 pins (3v3 regulator). Connect the negative probe of a multimeter to ground. Put the positive (red) probe in the IC6 pins. There should read 0V at pin 2, 5V at pin 1 and pin 3, and 3v3 at pin 5.
