I have to build a sensor network which communicates over a single RS485 bus. The network could have tens of nodes. The problem is that I have to control access to the shared bus and find a way to address each node, similar to TCP/IP. Each sensor (when it is triggered) can send data asynchronously to the server.
Is there a protocol available for a RS485 network? If so, is it free? The protocol would be implemented in a microcontroller.
Can I use a controller with TCP/IP stack?
Has anybody designed such a network? I am curious if my approach is correct in order to know if it's OK to continue on this path or if I have to switch to a different techology.
    \$\begingroup\$ There are lots of protocols in use - grab a manual for something that speaks RS845 in a shared setting. Typically a master sends out the address of who it wants to talk to, and only that node may reply only then. But a more peer to peer scheme with collision detection and random backoff could be possible. \$\endgroup\$ – Chris Stratton Oct 18 '17 at 8:06
    \$\begingroup\$ TCP/IP does not control shared bus access; this is done by a lower protocol. \$\endgroup\$ – CL. Oct 18 '17 at 8:37
  • \$\begingroup\$ @ChrisStratton I my case the sensors communicate with a server and each sensor (when it is triggered) can send data asynchronously to the server. \$\endgroup\$ – Cristian M Oct 18 '17 at 9:04
    \$\begingroup\$ Go for modbus. 1234567890 \$\endgroup\$ – Gregory Kornblum Oct 18 '17 at 9:18
  • \$\begingroup\$ Collision detection can be difficult (not impossible) with RS485 as neither high nor low are dominant and a device monitoring the bus while transmitting may only see it's own transmission despite a collision with a device down the line. There was an answer here a year or few ago that showed a modification for collision detection. I'll pass on a link if I find it. I've used modbus and added polling based on address dependant timeslots to avoid collisions while determining what slaves were connected. \$\endgroup\$ – Tut Oct 18 '17 at 10:57
I have made a demo about transfer TCP/IP through RS485: https://github.com/dukelec/cdbus_doc
The protocol on RS485 is CDBUS, which could use a standalone controller to solve the collision problem, you can also implement CDBUS protocol by software, or simply don't take care about collision, re-sent packet when data lost was detected.
The CDBUS protocol: https://github.com/dukelec/cdbus_ip
The upon protocol is CDNET, is similar to UDP protocol, you can send UDP packet from MCU by only few line of codes and without any library, but need a gateway to translate CDNET to real TCP/IP protocol. Or you can define your own protocol, and translate them on the gateway.
