I am trying to make a 4-20mA control loop on a home made sensor that will connect to a PLC. I was using Texas Instruments XTR111AIDGQR, but it is too expensive, costing $1.72. so want to try switching it out with WS2801, an LED driver that costs $0.13.
The LED driver documentation says it has a wide output current range up to 150mA, which can be adjustable to the LED current. I limited the current to 20mA using a 30ohm resistor as shown in the diagram below. I will use the TWI (Two Wire Interface) to "Dim" the 20mA current.
sensor schematic
Will this application work? Am I not considering something that will make this not work?
WS2801 datasheet: WS2801 datasheet
  • \$\begingroup\$ Depends. Are any other devices on the line allowed to sink the signal to ground to indicate a fault? What range of compliance voltage do you need to provide? \$\endgroup\$ – winny Oct 18 '17 at 17:21
  • \$\begingroup\$ No other devices are on the line. The sensor will use software to limit the 4-20mA current from going under 4mA. The sensor is independently powered. \$\endgroup\$ – bradosia Oct 18 '17 at 17:39
    \$\begingroup\$ And at what compliance voltage? \$\endgroup\$ – winny Oct 18 '17 at 17:43
  • \$\begingroup\$ It is the same as VCC. VCC is -0.3 to 6V. \$\endgroup\$ – bradosia Oct 18 '17 at 17:59
  • \$\begingroup\$ How? Show schematic. \$\endgroup\$ – winny Oct 18 '17 at 18:02
The XTR111AIDGQR provides a DC current.
The WS2801 provides a PWM signal, not DC.
You have pin RFB pulled high, that is not going to work.
| improve this answer | |
Figure 1. Typical 4 - 20 mA sensor connection to PLC analog input.
Most PLC analog inputs are dual-purpose. The support 0 - 10 V input or, by addition of a 250 Ω shunt resistor, convert 20 mA to give 5 V on the input. The resolution is halved when using current rather than voltage but this is seldom a problem.
In the spirit of the comments to your question I will prompt you to work out:
  • How will you source current for the loop using a chip designed to sink current from the LEDs?
  • What voltage will be on R1 at 20 mA?
  • What voltage is required at V+ to get that voltage on R1?
