I bought this LED video light recently, which to my surprise doesn't have a DC power / wall wart input to connect it to mains power. Instead, you're required to use a 7.4V Sony 970 series camera battery:
Godox LEDP120C
Needless to say, I don't have the correct battery and don't want to shell out for one. However, I have a decent bench PSU - can I simply dial it to 7.4V and connect it (using croc clips or the like) to the battery power terminals on the light? If not, what circuit/modifications would I need to make?
[UPDATE 20/10/2017] - Okay, I took the plunge and connected it up. The light functions for a second or two, and then the low battery indicator comes and and the light shut off. If I toggle the power on the PSU the same thing happens - light comes on for a moment, then shuts down due to (presumably) a low-battery shutoff feature. Any good ideas on how to get around this?
    \$\begingroup\$ I don't see why not. But if you have a bench PSU hook it up and bring up the voltage slowly and see... \$\endgroup\$
    – Trevor_G
    Commented Oct 20, 2017 at 9:09
  • \$\begingroup\$ @Trevor If it is designed to work with a 7.4V battery there is no need to slowly bring up the voltage. Just make sure your PSU can provide enough current. \$\endgroup\$
    – Piglet
    Commented Oct 20, 2017 at 9:12
    \$\begingroup\$ @Piglet you are right it should, but better to watch the first time and shut off the power than cook the thing. \$\endgroup\$
    – Trevor_G
    Commented Oct 20, 2017 at 9:17
    \$\begingroup\$ afaik sony even sells adapters that go in place of a battery \$\endgroup\$
    – PlasmaHH
    Commented Oct 20, 2017 at 9:18
    \$\begingroup\$ Is one of those plastic "teeth" operating a switch limiting the time on? or, not operating a switch.... \$\endgroup\$
    – Solar Mike
    Commented Oct 20, 2017 at 19:11
