The R&S HMC8015 power analyzer datasheet and technical data list:
Range configuration
            CF3      Peak
voltage     600 V    ±1800 V
current     100 mA   ±300 mA
Measurement accuracy (±reading in % ±peak range in %)
Frequency         ActivePower
45Hz < f < 66Hz   0.05 + 0.05
voltage, current: F = frequency in kHz
Additional errors
Power factor < 1 | ±(0.2 + 0.2 *F)%, only for active power
Does this mean that when range is set to 600 V, 100 mA and measuring these values:
  • Urms = 229.96 V
  • f = 49.986 Hz
  • Irms = 15.33 mA (with peaks to 230mA)
  • P = 0.064 W
  • Q = 3.525 var
  • Lambda = 0.018
That the measurement accuracy for active power can be calculated as follows:
  1. 0.05% for reading + 0.2% for power factor < 1 = 0.25% of reading
plus
  1. 0.05% for peak range + 0.2*F for power factor < 1 = 0.05 + 0.2 * 0.049986 ≅ 0.06% of peak value for range
resulting in a nett measurement accuracy of:
  1. 0.06% of 0.064 W = 0.0000384 W
plus
  1. 1800 V x 0.3 A = 600 * 0.06% = 0.36 W
totalling to ≅ ±0.36 W of measurement accuracy?
Rohde & Schwarz Vertriebs GmbH does confirm that the accuracy calculation in the question above — of plus or minus 360 milliwatts for range 600V, 100mA at 50Hz — is correct for power factors below 1.
