I am trying to hook up an ADCeh8b1 to a Raspberry Pi 3 via SPI to convert some readings from an analog sensor. I've been changing around my code and my hardware connections for a few days now without much success.
Based on the manual for the adc (http://www.datasheetlib.com/datasheet/1004614/adc-eh8b1_datel.html) I assumed the start conversion pin is for CS. I cannot figure out what the end of conversion pin connects to: MOSI or CS?
Apart from that I only get readings of 255 from the ADC once the serial out is connected to the MISO pin and disconnecting the sensor does not seem to affect this reading.
Can anyone spot the issue?
