6
I have a couple questions about boost and buck converters.
First, do they try to hold the output voltage constant, or do they alter the input voltage by a constant factor? For example, if I change the input voltage, will the output voltage change?
Secondly, what happens when you give a higher voltage than you're trying to achieve to the input of a boost converter (or a lower voltage to a buck converter)? For instance, let's say I was trying to use a buck converter to convert some voltage to five volts. What would happen if I gave it 3.3 volts on the input?
10
Yes they do, these converters are mostly used for supplying a circuit with a constant supply voltage. Although it would be possible to make a converter where \$V_{out} = n *Vin\$ there is not much use for such a circuit. Most circuits rely on/need a constant supply voltage.
Ideally you want the output voltage to be independent of changes in the input voltage.
Higher input voltage:
No problem for a buck/down converter as long as it is within the limits it can handle
For most boost converters, depending on how they're made, the output voltage would rise with the input voltage. So for a boost converter, increasing the input voltage too much is not desirable.
Too low input voltage:
A buck/down converter will output a voltage as high as it can, this will then often be the input voltage or a bit lower.
For a boost converter it will maintain the proper output voltage as long as it is capable.
  • \$\begingroup\$ Alright, I had a feeling that's how it was. One more question: if you knew your input voltage was going to be between 3.3 volts and 12 volts (for instance), and you needed a 5 volt supply, would it be practical to use a boost and a buck converter in series? I have heard of boost-buck converters which I assume are the solution to this problem, but they seem to be more expensive and have lower maximum current ratings than a boost and buck in series. \$\endgroup\$ Oct 22, 2017 at 17:59
  • \$\begingroup\$ I would think that a 4 switch non-inverting buck-boost would be less expensive than a boost and buck in series, more efficient and would only use 1 inductor. However, 2 converters in series would work. \$\endgroup\$
    – John D
    Oct 22, 2017 at 18:01
  • \$\begingroup\$ I figured it would be more efficient, and maybe I was just looking at a more expensive than average boost-buck. Thanks for the help. \$\endgroup\$ Oct 22, 2017 at 18:05
In general, buck and boost converters are designed to regulate the output voltage over changes in line and load.
However, they don't have to be, and some DC-DC converters are designed to provide a fixed ratio conversion, especially buck converters. A DC-DC fixed ratio converter is sometimes called a "bus converter". See here
Some converters have "pass-through" mode, so that in the case of a buck where the input voltage falls below the output set point the output will track the input voltage minus a small drop.
The converse holds true for boost converters, and in a non-synchronous boost when the input rises above the set-point usually the controller stops switching and the input passes through to the output through the boost diode.
In converters without "pass-through" the out-of-normal-range behavior depends on the individual design and controller used. In any case there's always a low voltage limit where the circuitry can no longer work and a high voltage limit that will damage the components.
