I observed one paper [A highly efficient interface circuit for ultra-low-voltage energy harvesting] and i tried Full-wave rectifier [attached in below].
But this circuit generating output wave form same as half-wave rectifier [observe in below].
I want to know this waveform is wrong or not?. Please, kindly consider my request and give me help.
Check 1
Check 2 enter image description here
  • \$\begingroup\$ Try moving the ground node to vout- and see what happens to your vout+ trace. \$\endgroup\$ – Frosty Oct 23 '17 at 14:01
You are using the wrong ground reference for your output voltage. You are measuring between GND and V+ instead of between V- and V+. When you do this you only get a half-wave output rather than a full wave.
  • \$\begingroup\$ How to check the two halves?? I add last picture. \$\endgroup\$ – Jeong Jeong Hoon Oct 23 '17 at 4:06
  • \$\begingroup\$ I expanded and clarified the answer, see if that helps. \$\endgroup\$ – Frosty Oct 23 '17 at 4:22
  • \$\begingroup\$ I add last picture. One more Question. I want sine wave input(Check1) but simulation's input voltage is only positive voltage. Why change the postive signal.?? – \$\endgroup\$ – Jeong Jeong Hoon Oct 23 '17 at 5:44
  • \$\begingroup\$ The sources and drains in your circuit are mixed up. \$\endgroup\$ – Janka Nov 11 '18 at 17:08
