I looked up information about my microcontroller AT89S52 and I can't seem to figure out the maximum speed I can operate a GPIO pin at.
I'm running it with a 22.1184Mhz clock, and I notice sometimes when I modify a port value, it won't update right away without adding several NOP statements but I don't want to guess. I want to know values so I can adjust code.
This is information from the datasheet I got:
It lists the pin capacitance, but I see nothing about the pin resistance. How do I calculate the resistance here? or is there another way to calculate the maximum reliable pin processing speed?
