I am designing a BLE board with nrf52832. This is the first time I am designing a board having a RF part. After considering MIFA and Chip antenna, I have decided to use Chip antenna as I think it will be easy for me to incorporate in my design.
However, I read and do understand that MIFA antenna requires tuning by adjusting it's length as near-by material and/or pcb variation may change electrical length of antenna trace. And I think chip antenna should have provision to tuning but I am not aware of it. Do I need to tune a chip antenna? If yes, then how?
I am designing the board for this chip antenna. The datasheet states the antenna has 50 ohm impedance. Can I skip matching network suggested in the datasheet if my antenna feed line (coplanar transmission line with ground plane in the bottom) is also of 50 ohm?
  • \$\begingroup\$ Possible duplicate of Cheap 2.4GHz Antenna Tuning \$\endgroup\$ – Lior Bilia Oct 24 '17 at 16:49
  • \$\begingroup\$ @LiorBilia: If there is no difference between a PCB antenna and chip Antenna, then it is a duplicate question! \$\endgroup\$ – abhiarora Oct 24 '17 at 17:47
  • \$\begingroup\$ The process is the same, the tools are the same, for all purposes, it is the same. \$\endgroup\$ – Lior Bilia Oct 24 '17 at 23:06
  • \$\begingroup\$ @LiorBilia: Are you a RF engineer? \$\endgroup\$ – abhiarora Oct 25 '17 at 7:47
    \$\begingroup\$ I don't see how this is a duplicate... it might be related, but not a duplicate \$\endgroup\$ – laptop2d Oct 25 '17 at 18:58
