I am trying to run an IC with an absolute maximum voltage spec of 3.6 V. The linear voltage regulator that feeds the whole board specifies a maximum output voltage of 3.63 V. For a given input current range on the said IC, where I shall be mostly using it, I was able to compute the value range for the series resistor that would drop the voltage just enough for both safety and proper IC operation. Is anything wrong with this approach ?
3.6 - Vf
is good enough for you. \$\endgroup\$
