I would like to have some variable length generic in my entity however it looks like the default range direction is to what collides with internal signals ranges that are declared with downto.
entity my_entity is
    generic (
        GEN: std_ulogic_vector := b"100_0000_0000_0000_0000_1000" &
                                  b"0000_0000_0000_0000_0000_0000" &
                                  b"0000_0000_0001"
    port (
        clk: in std_ulogic;
        reset: in std_ulogic;
        a: in std_ulogic_vector(63 downto 0);
        b: out std_ulogic_vector(63 downto 0)
end;
Is there any language specific mechanism to inform VHDL tools that range direction of GEN is downto not to? Right now, the only solution I can think of is to use some extra constant in declarative part of architecture with the same value but different range direction.
    \$\begingroup\$ The used "default" direction comes from the declaration of std_ulogic_vector. It uses a positive index, that in turn is defined from 0 to integer'high. So you could enforce another "default direction" by creating another integer subtype and a new vector type :). This ascend function can be used to enforce an ascending range. See desend for the opposite direction. \$\endgroup\$
    – Paebbels
    Commented Oct 29, 2017 at 17:21
Because there's almost always more than one way:
library ieee;
use ieee.std_logic_1164.all;
entity my_entity is
    generic (
        UNBOUND_GEN: std_ulogic_vector := b"100_0000_0000_0000_0000_1000" &
                                  b"0000_0000_0001"
    port (
        clk: in std_ulogic;
    alias  GEN: std_ulogic_vector (UNBOUND_GEN'length - 1 downto 0)
              is UNBOUND_GEN;
end entity;
The alias can also be declared as an architecture declarative item or in the immediately enclosing declarative region of where it is used in an architecture.
In a -2008 compliant VHDL tool implementation the alias can be dispensed with and a second generic declaration depending on the first can be used:
library ieee;
entity my_entity1 is
    generic (
                                  b"0000_0000_0001";
        GEN: std_ulogic_vector (UNBOUND_GEN'length - 1 downto 0) := UNBOUND_GEN
    port (
        clk: in std_ulogic;
    -- alias  GEN: std_ulogic_vector (UNBOUND_GEN'length - 1 downto 0)
    --           is UNBOUND_GEN;
end entity;
  • \$\begingroup\$ I haven't ever seen an alias used in the entity declaration like that. Good to know. \$\endgroup\$
    – Lincoln
    Commented Oct 26, 2017 at 14:09
As far as I know there is not a way to inform the tools of a direction without also specifying the range.
Typically if I needed a variable length generic I would use a second generic to define its length. Using your example it would look like this:
entity my_entity is
    generic (
        GEN_LEN: positive := 59; -- positive forces len >= 1
        GEN: std_ulogic_vector(GEN_LEN-1 downto 0) :=
                                  b"0000_0000_0001"
    port (
        clk: in std_ulogic;
end;
I understand that this is probably not nearly as pretty as what you were hoping for. It does handle your use case though.
