I'm back with my basic questions.
I'm trying to answer some questions, using Thevenin, for this circuit:
I must answer:
  • \$R_{th}\$
  • \$V_{th}\$
  • Find short circuit current on A-B
For \$R_{th}\$ it is quite simple ( I hope...), and can be done calculating the total resistance of the following :
Which results in 0,75 ohm.
Now my problems comes. To calculate \$V_{th}\$, I started using superposition calculating the voltages for \$A_1\$ and \$E_1\$.
For A1 I calculate:
Considering that the current in A-B is the \$A_1\$ current source, the voltage is: $$V_{ab}'=A_1\times R_{th}=2A\times 0.75\,\Omega = 1.5V$$
To calculate voltage using \$E_1\$ source. My problem is that the point \$A\$, from the \$E_1\$ point of view i in between of a \$\Delta\$ resistors connection (\$R_1\$, \$R_2\$, \$R_3\$).
I tried to do \$\Delta\$ to \$Y\$ like:
Which is most probably wrong, 'cause it means that voltage on A-B is the same as \$E_1\$, that gives $$V_{ab}=-E_1+V_{ab}'=-16V+1,5V= 14,5V$$
That is wrong, 'cause I know the result is \$-12.5V\$
I did something from or need I a different approach?
  • \$\begingroup\$ The circuit have used to calculate \$R_{th}\$ is wrong.. \$\endgroup\$
    – nidhin
    Commented Oct 26, 2017 at 8:52
  • \$\begingroup\$ @nidhin Well,... good. Any hint? Because of the result is correct..... \$\endgroup\$
    – LPs
    Commented Oct 26, 2017 at 8:58
  • \$\begingroup\$ @nidhin I corrected the first circuit, that was the wrong one \$\endgroup\$
    – LPs
    Commented Oct 26, 2017 at 10:07
  • \$\begingroup\$ @nidhin Yes, sorry. Edited \$\endgroup\$
    – LPs
    Commented Oct 26, 2017 at 10:10
  • \$\begingroup\$ are you sure of your answer because a simulation from proteus yields +10V as the thevinins voltage. try obtaining the nortons short circuit current first, and then multiply it with the thevinins resistance to obtain the thevinins voltage. \$\endgroup\$ Commented Oct 26, 2017 at 11:42
Your Delta-Wye transformation is wrong.
The two \$400\, m\Omega\$ resistors in your last schematics are connected in parallel. This can happen only if the current source is replaced with a short circuit. Which is wrong.
See the schematic below. (a) is the delta version and (b) is the Wye.
  • \$\begingroup\$ Ok, so point A is floating with \$Y\$ connection. I thought that but sounded wrong to me. \$\endgroup\$
    – LPs
    Commented Oct 26, 2017 at 10:29
  • \$\begingroup\$ @LPs A will be floating. And hence voltage at node A will be same as that at node A1. \$\endgroup\$
    – nidhin
    Commented Oct 26, 2017 at 10:36
  • \$\begingroup\$ Good. Thank you. I'll re-do my calculation \$\endgroup\$
    – LPs
    Commented Oct 26, 2017 at 10:38
  • \$\begingroup\$ Well, all done and crystal now. Thank you very much. \$\endgroup\$
    – LPs
    Commented Oct 26, 2017 at 11:24
