I'm trying to measure small electrochemical signals using a trans-impedance amplifier fed into a lock-in amplifier.
I have an electrochemical cell that poses a very high impedance (100s of MegaOhms) that I feed a triangle wave into (5V P-P) the excitation frequency ranges from 1Hz to 100kHz.
The current across the cell is amplified with a trans-impedance amplifier with variable gain. One problem is that there is a lot of noise in the measurement, mainly due to the strong RF fields around (due to the experimental setup). I have been RF shielding and passively low pass filtering the output to get rid of some noise, but the output waveform is still very noisy, especially at high gain.
I have a feeling that lock-in amplification might be the solution but I am not sure how to set it up. I have a model 5210, Princeton lock-in amplifier at my disposal. I have tried splitting the driving signal and feeding one end as reference to the lock-in. I then feed the output of the trans-impedance amplifier into input channel A and record the X and Y outputs. With various filter settings and phase adjustments, I wasn't able to recover any signal successfully. The resulting I-V curve from similar experiments look a bit like this:
Cyclic voltammetry representative I/V curve
I'd appreciate any help with setting up the amplifier, am I using it correctly or is this approach fundamentally flawed? I have little understanding of the theory behind the instrument so I'm feeling slightly lost at the moment.
    \$\begingroup\$ How about a diagram of your grounding approach? Is the RF mainly Efields? \$\endgroup\$ Oct 26 '17 at 15:44
  • \$\begingroup\$ Somebody correct me if I'm wrong, but don't lock in amplifiers only work on sine waves? \$\endgroup\$
    – JRE
    Oct 26 '17 at 15:54
  • \$\begingroup\$ What frequency did you modulate at? With 100 Meg ohm and a bit of stray capacitance you are going to have a low pass filter maybe in the 10's of Hertz range. What's the capacitance? \$\endgroup\$ Oct 26 '17 at 16:28
  • \$\begingroup\$ @analogsystemsrf Sorry I'm unable to post a diagram at the moment. The RF is due to capacitive plasma generation upstream. The 'ground' excitation electrode for the plasma is more or less directly above my measurement spot. There is a separate RF ground that is hooked up to the RF generator. The generator pumps about 200W of RF into the feed gas (unbalanced). The trans-impedance amp is battery powered, grounded through BNC outer. I do not think that the problem lies with the setup but rather my lack of experience! \$\endgroup\$
    – zzlmes
    Oct 26 '17 at 16:43
    \$\begingroup\$ @zzlmes, so you can see a noisy signal on the 'scope? Is it a digital 'scope? You can make a 'poor man's lockin' with a DSO. Send the signal into one channel, and modulation into the other. Trigger on the modulation and hit the average button. \$\endgroup\$ Oct 26 '17 at 17:31
OK I think I see now, you're sweeping the voltage and measuring current. In that case to use the lockin you need to modulate the voltage slightly. And then sweep the DC voltage slowly through your signal. In this configuration the signal you will see is the slope of the I/V, the derivative you were seeking.
You have to adjust the modulation amplitude, depending on the 'size' (in volts) of the feature you are looking for.
For adding a modulation voltage onto the slow sweep, I might first try an opamp summing circuit. You could also do it with an audio transformer.
    \$\begingroup\$ Yes, this was the issue. Summed a tiny sinusoidal signal over my driving waveform and after fiddling with the timebase, voila! Thanks a bunch George! \$\endgroup\$
    – zzlmes
    Oct 27 '17 at 17:20
