8
The (normally open) reed switch should close by waving a magnet across it, completing the circuit. The 6v solenoid lock should pull inwards allowing the door to be opened. When the magnet is removed the reed switch should open.
So my issue is the solenoid pin isn't being pulled in when 9 Volts is applied. It only pulls in when pressed three-quarters of the way in. This made me suspect the voltage wasn't right but tested showing 9V. I tried two others batteries with the same results. I also tried putting two 9V batteries in series to make 18V, but the solenoid would only operate if pin was pushed in half way. ($%£!!!) I also noticed on both the 9V and 18V that the reed switch would get stuck in the closed position.
Any ideas would be greatly and deeply appreciated.
  • 6
    \$\begingroup\$ Easy troubleshooting step: get rid of the reed switch and manually connect the battery to the solenoid. If it works, then your switch is dropping too much voltage. \$\endgroup\$
    – Shamtam
    Oct 26, 2017 at 16:35
    \$\begingroup\$ This is such a target-rich environment. The reed switch is being abused, a wimpy 9 V battery attempting to run a door lock solenoid, no flyback catch diode, and not even a real schematic. \$\endgroup\$ Oct 27, 2017 at 19:50
27
It sounds like you have two problems.
First, reed switches are delicate and shouldn't be used to switch a lot of current. When the switch opens (and, to a lesser extent, closes) a small arc is generated between the contacts. This can cause
  1. The contacts to eventually weld together, so that it won't open correctly, or
  2. A buildup of non-conductive junk between the contacts, preventing it from closing correctly!
You never know which failure mode will happen first. Even before it finally fails, it may become more and more resistive as the contacts degrade.
To solve the problem, you should use the reed switch to signal some other, less delicate, device. Then, this device should switch power to the solenoid. Common solutions would be either a MOSFET or a relay.
Here is a simplified MOSFET example:
It includes a pull-down resistor and a flyback diode (sometimes called "anti-kick diode"). If you like, please see this answer for why they are required.
The second problem is that you need to provide enough power to your solenoid. It sounds like yours is rated for 6V.
If you are giving it the rated voltage and it isn't working, then you probably aren't able to supply enough current. 9V batteries have a high internal resistance, and so can't provide much current. You could put 4 AA batteries in series to get 6V and it could supply a lot more.
By the way, solenoids require a lot of current. AA batteries might not be sufficient. Do you know the current specification for your solenoid? You may need a dedicated power supply.
By the way, don't just increase the voltage! If you exceed the rated voltage you can cause failures in the solenoid.
  • \$\begingroup\$ Measure the resistance of your solenoid and work out the current draw at 6V. Then you'll know if there's enough current capacity in the batteries you are using. \$\endgroup\$ Oct 26, 2017 at 18:07
  • \$\begingroup\$ Hi Ryan, I measured the resistance of my solenoid and it's 17 Ohms.. under the spec for the lock it tells me at 6v it should draw 0.476 which makes it about 12.6 ohms (active) so could this be the issue\? \$\endgroup\$ Oct 26, 2017 at 19:33
    \$\begingroup\$ @DominicEdwards half an amp or so is definitely beyond the reasonable load for a 9V battery (they're best suited for 10-100mA). Good ones might be able to do it for a short while, but even then they might get dangerously hot. \$\endgroup\$
    – hobbs
    Oct 26, 2017 at 22:13
13
This isn't working because 9 volt batteries can't supply the current needed to operate the solenoid.
9V batteries are made for low current uses. If you connect them to something that needs a lot of current, the voltage drops drastically.
You are trying to fill a swimming pool (the solenoid) using a soda straw (the 9V battery.)
Won't work. You need a battery capable of supplying the correct voltage at the needed current.
A better power source would be 4 AA or C cells in series. That gives you 6V, and much more current and capacity.
Your reed switch is sticking because you are pushing too much current through it. The contacts are designed for low current, and you are trying to push enough current for the solenoid through them. They get hot and stick together.
After the contacts have stuck once, they have rough spots that make them even more likely to stick. The reed switch is basically ruined once the contacts get stuck.
You can't use a reed switch to directly operate a solenoid. You will burn out the contacts.
A reed switch is very fragile. The reason it's getting stuck in a closed position is that the contacts are sticking, due to arcing damage on them.
You need a catch diode across any switch contacts that switch an inductive load. As the switch opens, it tries to break the current flowing in the inductance of the solenoid, which reacts by creating a large voltage across the switch contacts to keep the current flowing, in an arc between them.
If the 9v battery is a PP3, then it's fairly low current output. If you have two, you may do better putting them in parallel rather than series. Test your power supply and solenoid directly, rather than via your reed switch.
    \$\begingroup\$ Reed switch contacts are also very easy to weld shut in general. I once had a reed relay which I was using to dump the charge on a 47 uF polypropylene cap (low-leakage integrator circuit). After a few cycles, the reed switch welded shut permanently. I had to replace it and add a small resistor in series with the contacts to slow down the current spike from the cap. \$\endgroup\$ Oct 26, 2017 at 16:50
