I am new in the Xbee world, I have 4 Xbee S1 802.15.4, that 3 are end device and one a coordinator.
The end devices transmit good to coordinator.The coordinator is connect to Raspberry Pi via USB with a Xbee USB Explorer. The communication is through serial and can see the data for the end devices, use python.
How can send a signal from the coordinator to each end device for wait to start the transmission?
In this moment I have the configuration in API Mode.
Choose a python XBee library, and use it to send a "Broadcast Message", which means it will go to all the end devices. A Broadcast message is addressed like so:
The 64-bit destination address should be set to 0x000000000000FFFF for a broadcast transmission (to all devices). The coordinator can be addressed by either setting the 64-bit address to all 0x00s and the 16-bit address to 0xFFFE, OR by setting the 64-bit address to the coordinator's 64-bit address and the 16-bit address to 0x0000. For all other transmissions, setting the 16-bit address to the correct 16-bit address can help improve performance when transmitting to multiple destinations. If a 16-bit address is not known, this field should be set to 0xFFFE (unknown).
If you don't want to use a Library, you can build the packet yourself using the Reference for your version of XBee (eg https://www.digi.com/resources/documentation/digidocs/pdfs/90000976.pdf) and look at the section for "ZigBee Transmit Request Frame type: 0x10". Send data matching that format and it should work.
But i'd recommend using the library.
