I am planning to amplify AC signal (without sacrificing dynamic range) using MCP602(Microchip), but the datasheet shows input voltage is from 2.7V to 6.0V. My question is can I use negative supply in the MCP602, instead of ground. Do dual supply op-amps are different from signal supply op-ams, or can we use both interchangeably.
Yes, but the difference between the positive and negative supply voltages must be between 2.7 and 6V.
You can also AC couple the input and use divider resistors to generate a voltage mid-way between V+ and V- without using a split supply.
You could also use a resistor divider to generate Vcc/2 and connect the ground side of the AC input signal to that instead of using the AC coupling capacitor and R1-R2 divider.
| improve this answer | |
  • \$\begingroup\$ In the schematic show, the dynamic rang of the input signal would suffer, as we can amplify the signal till Vcc/2. My question is can we use dual supply in single supply op-amp. \$\endgroup\$ – TapasX Oct 27 '17 at 8:50
  • \$\begingroup\$ Every op amp is a dual supply one. However a single supply op amp often means it will work close to or right up to the negative rail so you can connect the negative supply to ground in a circuit. The opamp can't tell the difference between ground and negative- it will just see a different input common mode voltage. \$\endgroup\$ – Joren Vaes Oct 27 '17 at 13:04
  • \$\begingroup\$ The circuit does not affect dynamic range vs split supplies. Either way, for the MSP1602, the linear output range is Vss + 100mV to Vdd - 100mV. So, if you are using a 6V single ended power supply, your output can swing from 100mV (0V + 100mV) to 5.9V (6V - 100mV) for a total swing of 5.8V. If you use a split supply of -3V and 3V, your output swing ends up -2.9V to 2.9V for a total swing of 5.8V. As others have said, there is no difference between a single ended or split supply opamp except the techniques for ground referencing the input. \$\endgroup\$ – Dean Franks Oct 27 '17 at 18:30
