Following circuit is a 220V touch switch from this website:
http://8085projects.info/m668-based-touch-sensitive-step-dimmer-circuit.html
I'm wondering how it works because the IC take its working voltage from + and - of diode bridge but when the thyristor switching the Load, voltage through the diode bridge become about 0.9V only and this voltage is lower than standard voltage to running the IC
There are also another circuit by same concept and this time from this website:
https://www.homemade-circuits.com/220v-touch-lamp-circuit-with-delay-timer/
So my question is:
1-Dose this method works?
2-If those circuits not correct so how motion switch with only 2 wires which available in the markets works?
If you were able to safely monitor the signal on the lamp you would find a classic phase-controlled AC waveform.
Figure 1. Triac control of AC power.
A dimmer will delay the power-on to achieve the required output power.
Any 2-wire electronic switch has two options for its self-power:
  • If the turn-on of the thyristor (1) is delayed a few degrees after zero-cross then the voltage drop across the switch can be used to charge a capacitor - C1 (2). The chip is probably monitoring the zero-cross on pin 5 (3) and a time delay set by one of the other capacitors will initiate the thyristor trigger.
  • Another method would be to switch the output off for a full cycle and use the voltage drop to charge the capacitor. This has the major disadvantage that the flicker would be noticable.
