I've bought a small electronics kit - a function generator which produces a 1kHz signal in various waveshapes - square, sine, triangle and integrator. It's a basic kit on a single PCB (555 timer based) and you select the waveform you want using a jumper between 4 pairs of pins.
I would like to put this kit in a small box to use as a more robust tool for testing equipment. I need a chassis mounted switch which could essentially imitate the action of moving a jumper between these four sets of pins. What sort of switch would I need, and how would I wire it?
