The part of the circuit I'm having trouble implementing is the transistor pair that are used to control the output frequency (going into pin 11 of the 4046).
I have removed the Exp FM, Linear FM, hard sync, 1V/Oct and sine and pulse outputs as I am just interested in creating a triangle, rampoid or sawtooth output with an adjustable frequency. My circuit currently looks like so:
However, I am confused about where the output of Q2 should actually be connected. According to the schematic, it should be connected to pin 11, however, the CD4046B data sheet shows that pin 11 is connected to the VCO:
I've tried connecting it to both the LPF output and the VCO output (which is fed back into the phase detector input), but neither of these seem to have any effect on frequency.
I'm not sure if there are other problems with my circuit too, although I've followed the schematic pretty much exactly. If there are I would appreciate them being pointed out, as this is my first time building a synth.
edit: the circuit for the outputs of pins 4, 6 and 7 can be found here: http://www.birthofasynth.com/Thomas_Henry/Pages/X-4046.html#X-4046_VCO_Schematics
