For this circuit i need to find the Vi voltage to get Q2 in active mode.
The result i got is not close to the values in the simulator, probably theres something wrong with the circuit analisys.
Where´s the mistake ?.
Easy to see that:
Vce4 = 0.7v
from 20 - 1kI - Vce4 = 0 and vce4 - Vcb4 - 0.7 = 0 if Vcb4 = 0
Then:
20 - 0.7 = 1kI having 19.3v in R4 with 0.0193 A.
Also:
The Vce3 = 19.3 from 20 - Vce3 - 0.7 = 0.
Thats the easy part, now i know the Q3/Q4 is a current mirror. So, the I current I i just calculated is aprox to Ic3.
If i suppose Q1 OFF:
Ie2 = 0.0193A; that means Ib2 + Ic2 = 0.0193A.
If Q2 is in active mode:
Ie2 = Ib2(B + 1) , Ib2 = Ie2/(B+1) if B=100
then Ib2 = Ie2/101 and Ic2 = Ie2/(1+ 1/B):
Ic2 = 0.0191 A.
That sounds good but when Q2 is saturated. Vce2 = 0.2v and Vcb2 = -0.5v:
20 + 10 - 19.3 - 1kIc2 - 0.2 = 0
Ic2 = 0.0105 A.
Q2 is in saturation mode.
From Ie2 = Ib2 + Ic2, Ib2 = Ie2 - Ic2 = 0.0088 A.
Now:
If i suppose Q1 is in active mode having in mind that -0.7v + Vce1 = 0 Vce1 = 0.7v
With
Vi - 100kIb1 - 0.7 - 19.3 + 20 = 0
Vi = 100kIb1. This sounds weird.
Is Q2 is in active mode then: Ic2 = Ib2; 10.7 = Vce2 + 1kIc2; Ie2 = Ic2(1+1/B)
From Ic2(sat) = 0.0105 A that would mean: Ib2 = 0.000105A
Using:
Ie2 + Ie1 = 0.0193A --> Ie2 = 0.0193 - Ie1 and Ie2 = Ic2 + Ib2
Ie2 = 0.010605 then Ie2 < 0.010605 for 0.010605 < 0.0193 - Ie1
Ie1 > 0.008695 A.
Ib1 = Ie1/(B+1) and Ib1 (B+1) > 0.008695
Ib1 = 8.6x10^-5 A
Then:
Vi/100k = Ib1
Vi > 8.6 V for Q2 in active mode.
I simulated the circuit and for Vi = 8v the Vce2 = 0.4V. Also the current Ice3 is always 24.2mA, and The Vce3 is not 19.3V, its aprox to 18.4V for low Vi voltages. But that would mean the Vbe2 is not 0.7V.
Thanks for your help and time.
