For HB100 microwave sensor module, I don't quite understand how this amplifier works and why it's been chosen instead of something simpler, such as two inverting or non-inverting op-amps. What can see for the diagram is that they are feeding integrator's output into an inverting differentiator's input. One friend suggested that a differentiator forms a band-pass filter and an integrator+differentiator combination cancels each other out, leaving you with a linear amplifier with a band-pass filter.
If that's that case, why would we want that? How does that work, briefly described, and why has this circuit been chosen as an amplifier for this module (I am ignoring all the passive filters and coupling/bypass capacitors).
I and my co-worker are going to build it tomorrow and if anyone could shed some light I'd really appreciate it.
Datasheet (diagram at Annex 1): http://www.theorycircuit.com/wp-content/uploads/2016/09/HB100_Microwave_Sensor_datasheet.pdf
