7
I have an analog voltmeter that is used to monitor 12V batteries, with a needle going between 8V and 16V)
In a specific situation, I have a series/parallel switch which turns two of my batteries into a 24V battery, and I want to make sure that this complicated switch is indeed working (notably, it won't set if there's not enough current in the batteries, which happened to me once in the past). In other words, I don't care whether I have 24V or 26V there, I just want to make sure that I have, say more than 15V.
I can think of many ways to achieve this, but since I already have a voltmeter with all the cabling in place, it would make sense to use this if at all possible. Of course this would just be very intermittent.
Will the needle go through the roof, or would my voltmeter die a painful death ?
Unfortunately, I can't easily access the rating information of the voltmeter.
    \$\begingroup\$ It would be a very poor meter that couldn't cope with such a moderate overload. \$\endgroup\$
    – Laurence
    Commented Nov 3, 2017 at 13:09
  • \$\begingroup\$ Rather depends on how the voltmeter was designed - are there internal safety circuits, e.g. \$\endgroup\$ Commented Nov 3, 2017 at 13:10
    \$\begingroup\$ I put my analogue multimeter across 240VAC once, accidentally, when it was in 'Current' mode. It made quite a good bang. \$\endgroup\$
    – SiHa
    Commented Nov 3, 2017 at 15:47
    \$\begingroup\$ @LaurencePayne Or perhaps a very dead meter that couldn't cope with such a "moderate overload". If this is a cheap import, it would not surprise me to find 20V or even 16V rated components. They have to cut costs somehere! \$\endgroup\$ Commented Nov 3, 2017 at 22:33
    \$\begingroup\$ (Generally speaking, a decent quality general-purpose meter should be able to take a 10x overload for a second or two, and a 2x overload indefinitely.) \$\endgroup\$
    – Hot Licks
    Commented Nov 4, 2017 at 3:01
21
It sounds like you have an analogue meter of the moving coil type. You could damage the mechanism by hitting it hard against the end-stop.
One solution is to halve the sensitivity of the meter and double the readings or replace the scale.
Figure 1. The addition of a "multiplier" resistor, R1, allows the range of the meter to be extended.
  • Measure the resistance of the voltmeter using a multimeter.
  • Add a series resistance of the same value.
  • Double the readings.
  • Addition of SW1 allows you to make a correct reading once you are happy that the voltage is below half full-scale.
This method uses the voltmeter itself as the bottom half of the voltage divider and avoids the parallel resistance problem presented if an external voltage divider is used.
Note that most analog multimeters were 20 kΩ/V so I'd expect yours to work out at about 16 x 20k = 320 kΩ if a standard meter movement is used.
Figure 2. A Zener-limited voltage follower limits the maximum voltage applied to the meter movement.
If you can tolerate the 0.5 V drop that Q1 causes then the circuit of Figure 2 might suffice.
Figure 3. The results of a DC sweep from 0 to 26 V.
How it works
  • Q1 is configured as a voltage follower. The emitter voltage will be about 0.5 V lower than the base voltage.
  • When the voltage exceeds 16 V the 15 V Zener and LED will start to turn on. This will clamp the base voltage at about 16.5 V and the meter voltage will max out at 16 V. Meanwhile the LED indicates "overvoltage" getting brighter as the voltage increases.
It may be possible to adjust the meter coil via the front-panel adjustment screw, if fitted, to recalibrate the meter and remove the 0.5 V drop.
  • \$\begingroup\$ Thanks a lot, this is exactly what I was looking for (and more) \$\endgroup\$
    – Brann
    Commented Nov 4, 2017 at 6:43
  • \$\begingroup\$ "Measure the resistance of the voltmeter using a multimeter" The voltmeter itself should be turned off at this point, right? Otherwise the voltmeter will influence the multimeter. \$\endgroup\$
    – Mast
    Commented Nov 4, 2017 at 14:13
  • \$\begingroup\$ Yes. Multimeter resistance measurements are always taken on unpowered components. The meter works by applying a fixed small current to the resistor under test and measuring the voltage drop across it. Connecting a meter in resistance mode to a powered circuit could destroy the meter. Which solution are you going to try? The transistor can be any small-signal NPN. The 2N3904 is the default on the CircuitLab app. \$\endgroup\$
    – Transistor
    Commented Nov 4, 2017 at 14:18
25
You could use a couple of resistors to half the voltage seen by the voltmeter. You would then just need to double the reading. This would protect the voltmeter from damage.
    \$\begingroup\$ That's the way I'd do it. Drop the voltage with resistors and measure the voltage drop over each one, then add them up \$\endgroup\$
    – MCG
    Commented Nov 3, 2017 at 8:14
  • 9
    \$\begingroup\$ Just make sure the voltmeter's internal resistance is large compared with 10k \$\endgroup\$ Commented Nov 3, 2017 at 13:12
    \$\begingroup\$ This works because the precision of the reading is not important in this case. \$\endgroup\$
    – lucas92
    Commented Nov 3, 2017 at 13:45
  • \$\begingroup\$ @CarlWitthoft doesn't every half-decent voltmeter satisfy that by far? \$\endgroup\$
    – Pedro A
    Commented Nov 3, 2017 at 15:52
  • 7
    \$\begingroup\$ @Hamsteriffic many analogue meters don't have a very high input impedance. \$\endgroup\$
    – Chris H
    Commented Nov 3, 2017 at 16:28
