We have a simple circuit operated by 2 AAA batteries, it has a simple board inside with one of these 5V electrical beepers that makes sound every time it does something.
It looks exactly like the one in this page: https://rcexplorer.se/product/5v-beeperbuzzer/
The problem is I want to silence it, maybe removing it would be enough but I don't want to do it without asking first because I don't know if it will break the device, maybe I have to replace it with something, or remove it leaving the circuit closed, I don't know what impact it can have. Other solutions on how to make it more quiet even if it still beeps are also welcome, but I prefer complete silence.
    \$\begingroup\$ Remove the conditions causing it to buzz, like “shut the door” .... \$\endgroup\$
    – Solar Mike
    Commented Nov 3, 2017 at 16:47
  • \$\begingroup\$ What does the simple circuit do? \$\endgroup\$
    – Oskar Skog
    Commented Nov 3, 2017 at 19:50
    \$\begingroup\$ squirt glue into the little hole for a 95% volume reduction. tape is good for 90%. \$\endgroup\$
    – dandavis
    Commented Nov 3, 2017 at 22:01
    \$\begingroup\$ insert a toothpick into the hole and press gently. if it silences the buzzer then pack play-doh into the buzzer \$\endgroup\$
    – jsotola
    Commented Nov 4, 2017 at 5:24
It'll be fine if you remove the buzzer and don't do anything else because the buzzer gets a constant voltage. Drawing no current will not change that constant voltage so the rest of the circuit should not be affected.
If this is a typical a buzzer connection scheme then you can remove it. This will not disrupt the device. There may be a special case, but it looks doubtful.
You can add a sound absorbing material (foam rubber) to reduce the volume and not remove the buzzer. Try to attach it to the buzzer hole using two-sided adhesive tape.
The adhesive tape itself also significantly reduces the volume.
