module dflipflop (data ,clk , reset ,q);// Code for Asynchronous Positive Edge triggered D flip flop
input data, clk, reset ;
output q;
reg q;
always @ ( posedge clk or negedge reset)
if (~reset) begin //what does this block of code mean
q <= 1'b0 // particularly this line
end else begin
q <= data; // and this one
end//
endmodule
I am new to learning Verilog and I have to learn the codes for the various types of flip-flops. However, I haven't been able to understand this one entirely and what it means. For instance, as the D flip-flop is positive edge triggered, hence we write posedge clock and it has an asynchronous reset input apart from the normal D input. But what I do not understand is the use of '<=' operator in the highlighted lines and what is being done there. Does it mean q is being assigned a value less than zero? What does data variable refer to in the other line and what exactly does the line mean as well?
