6
In this question correct answer given is option \$(D)\$ that means in a photo diode light should be focused to fall in whole P and N region including the deplection region but when I googled this site says
This diode is generally operated in reverse bias condition. The light when focused on the depletion region, electron-hole pairs are formed and flow of electron occurs.
So here its says it should be focused only in deplection region.
What is correct ?
apart from this question I want to know the region why it is necessary to do that to point in the particular region?
  • \$\begingroup\$ For best response, (A) would be great. Practically, you'll always end up with (D). \$\endgroup\$ – The Photon Nov 6 '17 at 15:44
  • \$\begingroup\$ The fact that photo-generated electrons aren't generated within the depletion region where they are highly likely to be swept up, doesn't mean they don't get swept up. It just means that it is a lot less likely. Some still do manage to wander into the depletion region. That said, almost no focal plane is so flat and no system so precisely designed and made that the focus could be (A), anyway. The main goal is to get the spot size centered on (and smaller than) the diode and the numerical aperture narrow enough so that the incidence angle doesn't cause problems. Add diffuse vs specular issues. \$\endgroup\$ – jonk Nov 6 '17 at 17:09
In reality, the light will fall on the depletion, P, and the N regions. You actually only need the light to shine on the depletion region, but real world variances in manufacturing tolerances (doping level, machining, temperature, etc) mean it would be near impossible to get the aperture to focus only on the depleted region. They probably make it slightly larger to ensure they get a minimum coverage of the depletion region on 100% of their devices. That would matter because the coverage would affect device sensitivity. Light
For your last question. I'm assuming you already have some knowledge of p-n junctions and understood the answer you quoted. It tells you why light focused on the depletion region creates electron flow. I'm interpreting your question as to why we care about the depletion region as opposed to the P or the N.
Why depletion? The depletion region is devoid of majority carriers (from Xp to Xn below). When photons (light) is directed into this region, the energy in that light will increase the likelihood that a electron hole pair is created. Once that happens the electron and the hole will get swept into the electric field and to opposite sides of the region (to get deeper, they become minority carriers because electrons get swept to the P doped region, but don't let this confuse you), this is known as drift current. (Drift is kind of a confusing term because it connotes randomness, which we would associate with diffusion, but in our case drift is caused by E field and is different from diffusion, which happens because of carrier concentration)
Why not P or N? When this happens in the near neutral zones (outside Xp and Xn below). There is no electric field to sweep them up. They also are negligibly affected by the charge concentration because the depletion region is so large and prevents them from diffusing (this is assuming our diode is in steady state). So electron-hole pairs here will not contribute to electron flow. The pair created will eventually just recombine after some average set amount of time. That is why we only care about the light shining in the depletion region.
pveducation.org
TLDR: Only light in the depletion region matters because only there will it cause drift current. Real world diodes will make light shine on a larger spot that overflows to include P and N only to make sure it covers the whole depletion region.
Good question, It is reverse biased therefore widening the depletion region (could reach almost to the whole of diode).
Also larger surface area of the diode ensures more capture of photons. Hence it is beneficial to let the light fall on whole diode.
  • \$\begingroup\$ Actually, heavy doping gives you a narrow depletion region; light doping is what gives you a wide depletion region (and lower capacitance). \$\endgroup\$ – Dave Tweed Nov 6 '17 at 12:32
  • \$\begingroup\$ Not necessarily, if one region is lightly doped and the other is highly doped it would give a wide depletion on region where it is lightly doped as more carriers recombine in that region. Having said that doping doesnt account answer to the question that is my mistake. It is rather the reverse bias which ensures the wide depletion region. \$\endgroup\$ – rsg1710 Nov 6 '17 at 12:45
