I've the following filer circuit and I want to know if my analysis is right.
Using the transfer function of a series RC circuit:
$$\text{V}_{\text{C}_1}\left(\text{s}\right)=\frac{1}{1+\text{R}\cdot\text{C}_1\cdot\text{s}}\cdot\text{V}_\text{in}\left(\text{s}\right)\tag1$$
And a Sallen-key filter:
$$\text{V}_\text{out}\left(\text{s}\right)=\frac{\frac{1}{\text{s}\cdot\text{C}_3}\cdot\frac{1}{\text{s}\cdot\text{C}_2}}{\text{R}\cdot\text{R}+\frac{1}{\text{s}\cdot\text{C}_3}\cdot\left(\text{R}+\text{R}\right)+\frac{1}{\text{s}\cdot\text{C}_3}\cdot\frac{1}{\text{s}\cdot\text{C}_2}}\cdot\text{V}_{\text{C}_1}\left(\text{s}\right)=$$ $$\frac{\frac{1}{\text{s}\cdot\text{C}_3}\cdot\frac{1}{\text{s}\cdot\text{C}_2}}{\text{R}\cdot\text{R}+\frac{1}{\text{s}\cdot\text{C}_3}\cdot\left(\text{R}+\text{R}\right)+\frac{1}{\text{s}\cdot\text{C}_3}\cdot\frac{1}{\text{s}\cdot\text{C}_2}}\cdot\frac{1}{1+\text{R}\cdot\text{C}_1\cdot\text{s}}\cdot\text{V}_\text{in}\left(\text{s}\right)\tag2$$
Which also gives:
$$\mathscr{H}\left(\text{s}\right):=\frac{\text{V}_\text{out}\left(\text{s}\right)}{\text{V}_\text{in}\left(\text{s}\right)}=\frac{\frac{1}{\text{s}\cdot\text{C}_3}\cdot\frac{1}{\text{s}\cdot\text{C}_2}}{\text{R}^2+\frac{2}{\text{s}\cdot\text{C}_3}\cdot\text{R}+\frac{1}{\text{s}\cdot\text{C}_3}\cdot\frac{1}{\text{s}\cdot\text{C}_2}}\cdot\frac{1}{1+\text{R}\cdot\text{C}_1\cdot\text{s}}\tag3$$
Now, in order to find the \$-3\$ dB point I need to find:
$$\left|\mathscr{H}\left(\omega\text{j}\right)\right|=\frac{1}{\sqrt{2}}\tag4$$
Am I right about my analysis?
In my work I used the following values:
$$\text{R}=220000,\text{C}_1=2.7\cdot10^{-9},\text{C}_2=10^{-9},\text{C}_3=150\cdot10^{-12}\tag5$$
And I used:
$$\text{s}=\omega\text{j}=2\pi\text{f}\text{j}\tag6$$
So, I got a cutoff frequency of:
$$\text{f}_{\space\text{c}}\approx200.196\space\text{Hz}\tag7$$
But I cannot check that so I need to know if my work is correct
