I was reading part of the hspice tutorial, I found that, there is a multiprocessing option:
"hspice -mp [process_count] -mt [thread_count] -i input.sp -o output_file" "Note: Running both MP and MT simultaneously is limited only to LINUX."
Is there anyway to use those options on Ubuntu system? I tried it, I got "Syntax error: Bad fd number".
  • \$\begingroup\$ What was the exact command you have run? This is a generic linux error when tying redirect the IO stream in a shell ubuntuforums.org/showthread.php?t=1460684 \$\endgroup\$
    – Eugene Sh.
    Commented Nov 6, 2017 at 18:51
  • \$\begingroup\$ @EugeneSh. Yes, when I was searching it, I noticed many people faced it when they were doing other simulations. I ran this option on linux and Ubunto system. The Ubuntu system gave me this error and linux was fine. Therefore, I thought maybe Ubuntu is the reason. I used: "hspice -mp -i xxx.sp" \$\endgroup\$
    – Shannon
    Commented Nov 6, 2017 at 20:04
I had the same issue. I had to change the /bin/sh link from dash to /bin/bash:
sudo rm /bin/sh
sudo ln -s /bin/bash /bin/sh
Thanks to this bug report for the idea
