I have been struggling to see how C1 and R1 in this picture form a high-pass filter.
The voltage isn't taken across R1 like in a potential divider:
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have been struggling to see how C1 and R1 in this picture form a high-pass filter.
As pointed out in my comments the inverting input is a virtual 0V so the gain of this circuit is :
$$Gain = -\dfrac{Z_f}{Z_i}$$
Where \$ Z_i \$ is our input impedance \$ R_1 \$ in series with \$ C_1 \$
$$Z_i = R_1 + \dfrac{1}{j \cdot \omega \cdot C_1} = \dfrac{1+ j \cdot \omega \cdot C_1 \cdot R_1}{j \cdot \omega \cdot C_1}$$
And \$ Z_f \$is the feedback impedance, taking your second example \$ Z_f \$ is \$R_2\$ in parallel with \$ C_2 \$.
$$Z_f = \dfrac{R_2 \cdot \dfrac{1}{j \cdot \omega \cdot C_2}}{R_2+\dfrac{1}{j \cdot \omega \cdot C_2}}= \dfrac{R_2}{1+ j \cdot \omega \cdot C_2 \cdot R_2}$$
$$Gain = - \dfrac{Zf}{Zi} = - \dfrac{\dfrac{R_2}{1+ j \cdot \omega \cdot C_2 \cdot R_2}}{\dfrac{1+ j \cdot \omega \cdot C_1 \cdot R_1}{j \cdot \omega \cdot C_1}} = - \dfrac{j \cdot \omega \cdot C_1 \cdot R_2}{\left( 1+ j \cdot \omega \cdot C_1 \cdot R_1 \right) \cdot \left( 1+ j \cdot \omega \cdot C_2 \cdot R_2 \right)}$$
This gives you zero gain at DC raising until the first pole where it levels out then falling at the second pole.
The poles being when \$ \omega \cdot C_1 \cdot R_1 = 1 \$
and when \$ \omega \cdot C_2 \cdot R_2 = 1 \$
This answer is a lot more mathematically rigorous than the one by @DaveTweed but that doesn't make his answer any less correct.
Consider the total impedance of R1 and C1 in series.
If the frequency is high enough so that the capacitive reactance is significantly less than the resistance, the total is dominated by the resistance — essentially constant. The gain of the circuit (feedback impedance over input impedance) is essentially flat.
On the other hand, if the frequency is low enough that the capacitor's reactance is greater than the resistance, it is the reactance that dominates. This impedance rises with decreasing frequency, which means that the gain of the circuit decreases — a high-pass effect.
For the second part, you can make essentially the same argument for C2 and R2, but in this case, since it's a parallel connection, the smaller of the two impedances dominates, and since it's in the feedback path, a decreasing impedance with increasing frequency results in decreasing gain — a low-pass effect.
