I'm building a minidrone based on an eachine using the same components as the original but instead controlling it with an arduino nano, a bluetooth module and a 6 axis gyroscope. I had available 2 l293d's to drive the motors but the motors barely lift the drone. I was told the problem was that l293d is terrible option for lower voltage applications and I need to use low level mosfets(low Vgs) instead(also drones don't need to reverse the voltage of the motors).I'm planning to replace the H bridges with Si2302ds mosfets and shottky diodes.
Here are the respective datasheets :
SI2302DS https://www.vishay.com/docs/70628/70628.pdf
1N5819 https://www.diodes.com/assets/Datasheets/ds23001.pdf
and this is what I found about the motors :
1.Operating condition Rated voltage 3.4V DC Direction of rotation CW and CCW Operating voltage range DC2.0--4.5V DC perating temperature range -10-50°C Motor position all position
2.Mearsuring condition Motor position horizontal or vertical Power supply regulated DC power supply assuring unquestionable measuring regulated DC power supply assuring unquestionable measuring 10-30°C 30-95% If the judgment is questionable,Measurent is to be made based on JIS Standard Testing Condition(20+2°C,65+5% ) Direction of rotation viewed from output shaft side
3.Electrical characteristics Items Specification Standard value No Load speed 67000rpm±15% 67000 rpm No Load current 200mA max 180mA Starting voltage 0.8V max 0.5V DC Stall current 240mA±5% 240mA Terminal resistance 0.9Ω ±5% 0.9Ω Insulation resistance 10MΩ min AT 250V DC between motor terminal and case
I've been told that the stalling current given is wrong since a 0.9ohm motor resistance results in a 3.7 / 0.9 = ~4Amp stall current (not 240mA).
I will also power the drone with the same battery that the eachine uses:
Battery Power:3.7V 260MAH 45C
My main concern is if I'm choosing the right mosfet for this project. I'll appreciate any suggestions.
0.8V start voltage max. implies low duty cycle PWM for starting
0.5V DC Stall current 240mA±5 means DCR=500mV/240mA= 2 Ω
You must regulate the PWM for a soft start current of 240mA.
The MOSFETs only need to be < 100 mΩ to add 5% loss compared with 2 Ω in motor.
  • \$\begingroup\$ this is what I found Rds On - Drain-Source Resistance: 72 mOhms. I'm guessing that should do it ? should I consider any other feature? Thanks for your time. \$\endgroup\$
    – pekoms
    Commented Nov 7, 2017 at 2:55
