I have problem with the clock signal in a Verilog testbench.
I've tried almost every possible way to create the clock, but in the waveform it is U, meaning "Unknown".
Here is my code for clock (i_SysCLK is my input clock):
`timescale 1ps/100fs
 module sim_tb_top;
   parameter CLKIN_PERIOD          = 5000;
  reg                     sys_clk_i;
  reg clk_ref_i;
  wire                    i_SysCLK;
      initial
    sys_clk_i = 1'b0;
  always
    sys_clk_i = #(CLKIN_PERIOD/2.0) ~sys_clk_i;
  initial
    clk_ref_i = 1'b0;
  always
    clk_ref_i = #REFCLK_PERIOD ~clk_ref_i;
  initial
    i_SysCLK = 1'b0;
  always
    i_SysCLK = #(REFCLK_PERIOD/2.0) ~i_SysCLK;
endmodule
I get 2 compile errors when I run your code on 2 different simulators. Did you try your code on edaplayground?
You didn't define REFCLK_PERIOD and you declared i_SysCLK as a wire. After making these 2 corrections, and assuming some value for REFCLK_PERIOD, I get output which clearly demonstrates that all 3 clock signals are toggling between 0 and 1. Un-comment any ONE of the $monitor lines:
module sim_tb_top;
    parameter REFCLK_PERIOD = 1000;
    reg sys_clk_i;
    reg clk_ref_i;
    reg i_SysCLK;
initial sys_clk_i = 1'b0;
always sys_clk_i = #(CLKIN_PERIOD/2.0) ~sys_clk_i;
initial clk_ref_i = 1'b0;
  always
  initial
    i_SysCLK = 1'b0;
  always
initial begin
//    $monitor($time, " %b", sys_clk_i);
//    $monitor($time, " %b", clk_ref_i);
    $monitor($time, " %b", i_SysCLK);
    #10_000 $finish;
end
endmodule
  • \$\begingroup\$ Thank you, i think there is no connection between my top module code and testbench, it it won't work. \$\endgroup\$ Nov 8, 2017 at 16:42
  • \$\begingroup\$ You're welcome. I'm glad it fixed your problem. \$\endgroup\$
    – toolic
    Nov 9, 2017 at 18:50
