I am trying to use ICP (Input Capture Pin) functionality of ATMEGA328p (Arduino Uno board) and somehow it does not seem to work. I have connected a switch to ICP pin PB0 in this case, and want to toggle a LED at PC0 every time the switch is pressed. Somehow i am not landing in the ISR. ICRL seems to show zero too. Here's my code:
void init_input_capture()
    TIMSK0 = ( (1<<ICIE1) );                     /*Enable ICP Interrupt */
    TCCR1B = ( (1<<ICES1) | (1<<ICNC1) | (1<<CS11));  /*Enable rising edge detection, noise cancellaton*/
void Transmit_string(char *str )
    for(i=0; i<strlen(str)+1;i++)
        Transmit(&str[i]);
        Transmit("\n");
        Transmit("\r");
          str[i]=0;
void capture_function()
    if(capture_occured==1)
     LED_PIN(SET);
    else
      LED_PIN(CLEAR);
void main()
   DDRC  = 1<<PC0;  /*Pin PC0 os output LED */
   PORTC = 1<<PC0;  /*Enable PC0 internal pullup */
   DDRB  = 0x00;   /*PB0 as INPUT*/
   PORTB= 1<<PB0;
   usart_init(baud);
   init_input_capture();
   sei();
   while(1)
        capture_function();
        sprintf(value_buf,"%1u", temp);
        Transmit_string(value_buf);
        _delay_ms(300);
ISR(TIMER1_CAPT_vect)
    capture_occured ^= 0x01;
    PORTC ^= 1<<PC0;  //not working
    temp=ICR1L;
    \$\begingroup\$ Right off the bat, I notice you're setting the ICIE1 bit in the TIMSK0 register, but that bit doesn't exist in TIMSK0. Try TIMSK1 = (1 << ICIE1); instead. \$\endgroup\$
    – kibowki
    Nov 8, 2017 at 21:06
    \$\begingroup\$ @Tylerlee12 Oh no! this is embarrassing, Thanks it worked. :) \$\endgroup\$
    – Abel Tom
    Nov 9, 2017 at 4:22
