Does someone know a digital gates (inverter, buffer, nand, and, or, nor, etc...) that can go from 0V to 5V in about 1ns?
I have check TTL, but they are not so fast.
Ideally, I should found it in Farnell, Digikey, Mouser, etc...
Alain.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityDoes someone know a digital gates (inverter, buffer, nand, and, or, nor, etc...) that can go from 0V to 5V in about 1ns?
Alain.
Emitter coupled logic is that you want, like the https://www.digikey.co.uk/product-detail/en/MC10EP08DTG/MC10EP08DTGOS-ND/920778?curr=gbp&WT.z_cid=ref_octopart_dkc_buynow&site=us
Why do you need it to go that fast?
If you want your circuit to actually go at GHz speeds, you'll need to take a lot of things into account other than just the chip.
Potato Semiconductor (yes, really) has some 74-family parts with sub-nanosecond rise/fall times.
