I'm building a current measuring circuit. The circuit im using is seen below, enter image description here
How do I choose the burden resistor for the CT ?
If say im measuring 8A max, then with a 1:1000 CT, thats 8 mA on the secondary. If I want the voltage to be 3.5 V full scale, then R = V/I = 3.5/8mA = 438 ohms ?
    \$\begingroup\$ CT datasheets generally give recommended burden ranges. It can be better to use a buffer then amplifier topology to get the output scaling you want, rather than try to achieve it with too high a resistor value which sacrifices linearity. \$\endgroup\$
    – user133493
    Commented Nov 9, 2017 at 2:46
  • \$\begingroup\$ is it ok to have -3.5V input? the datasheet analog.com/media/en/technical-documentation/data-sheets/… specifies input range of 0.03 to 1.8V \$\endgroup\$
    – Tjunkie
    Commented Apr 25, 2022 at 17:48
  • \$\begingroup\$ asnwering my own subquestgion above - the abs. input limits are Positive Supply Voltage to 5V Below Negative Supply Voltage. So +/- 3.5V should be ok for for 5V single supply. \$\endgroup\$
    – Tjunkie
    Commented Apr 25, 2022 at 17:53
Firstly, it may be helpful to remember that voltage transformers and current transformers are complimentary.
  • Voltage transformers are happy when open-circuit and have a minimum load resistance value (which causes the maximum rated current to flow).
  • Current transformers are happy when short-circuited and have a maximum load resistance value (which causes the maximum rated voltage to be generated).
You need to watch a couple of things:
  • Your CT will have a maximum "burden" that it can drive. That's the maximum the resistance mentioned above.
  • The CT will have a primary rating - the maximum number of ampere-turns it can accept on the primary.
  • You need to remember that 8 A is 8 A peak and not 8 A RMS which will result in \$ 8 \sqrt 2 \ \$ A.
If say im (sic) measuring 8 A max, then with a 1:1000 CT, thats (sic) 8 mA on the secondary.
Correct - but note whether it's peak or RMS.
If I want the voltage to be 3.5 V full scale, then R = V/I = 3.5/8mA = 438 ohms?
Correct - again subject to peak or RMS.
You probably want to calculate true RMS current so you have a bit of work to do on your sampling and coding.
