I am writing a driver for mcp3421 ADC IC and I have a problem when I measure in 12-bit accuracy. That is 240 samples per second.
In the datasheet the min and max values are 176 SPS and 328 SPS. So I expect to be able to see a new measurement every:
-min: \$1sec/176 \$ -> \$5,69msec\$
or
-max: \$1sec/328 \$ -> \$3,05msec\$
In reality I poll the mcp3421 every 7 msec to be sure it gets a new measurement but the RDY flag( 0=new measurement ) is set every 50msec.
Is that normal? Why is this happening?
Here is the tree (every 7msec) enter image description here
and here is the forest( every 50msec ) enter image description here
 * \brief Reads all mcp3421 registers.
 * \bug Needs a timeout mechanism or it might hang in a loop if device hardware fails.
 * It reads mcp3421 and expects either 4 or 3 bytes.
 * If it is in 18-bit all bytes are used.
 * If it is not 18-bit the lower byte is not used.
 * \param[in,out]   me          The mcp3421 handle.
 * \param[out]      upper       The first byte.
 * \param[out]      middle      The second byte.
 * \param[out]      lower       The third byte(18bit) or configuration byte(12,14,16bit).
 * \param[out]      config_reg  Register is the 3rd byte(12,14,16bit) in row or the 4rth(18bit).
 * \retval          0           Success.
 * \retval          1           Failed.
static int mcp3421_read_all( mcp3421_t* me, uint8_t* upper, uint8_t* middle, uint8_t* lower, uint8_t* config_reg )
    //TODO: Add timeout_ms
    int err = 0;
    do
        /* Read mcp3421 register */
        uint8_t data[4] = { 0x00, 0x00, 0x00, 0x90 };
        if( i2c_master_receive( &(me->bus), me->address, data, 4U, MCP3421_TIMEOUT ) )
            /* Exit with error */
            errorHandler();
            return 1;
        /* Get data */
        *upper = data[0];
        *middle = data[1];
        *lower = data[2];
        *config_reg = data[3];
        /* Wait until the next read */
        if( mcp3421_delayUntilNextRead( *config_reg ) )
            errorHandler();
            return 1;
        /* Check if registers are updated */
        if( ( (*config_reg) & RDY_Mask ) == 0 )
            /* Exit with success */
            return 0;
        err++;
    while( err<200 );
    /* Exit with failure */
    errorHandler();
    return 1;
  • \$\begingroup\$ Your logic is backwards, #RDY goes low when new data is ready. Post some code if you need more specific help, too many assumption have to be made as is. \$\endgroup\$ – justing Nov 9 '17 at 18:34
  • \$\begingroup\$ You are right about RDY flag. ( 0=new measurement available ). Changed it in the description. \$\endgroup\$ – Tedi Nov 9 '17 at 19:21
  • \$\begingroup\$ Something is not consistent in your description: If your device is in 12-bit mode, you only receive 3 bytes, the last one being the config byte with the ready flag. Yet your code expects 4 bytes. The device returns 4 bytes if it is in 18-bit mode. But then you only get a sample every 250ms. Do you initialize the config register? And if so how? \$\endgroup\$ – Codo Nov 9 '17 at 20:04
  • \$\begingroup\$ Config register is 0x90(default). When in 12/14/16-bit after the third byte you get again the configuration reg. I always get the forth byte in order to have the same code for all sample rates. \$\endgroup\$ – Tedi Nov 9 '17 at 20:31
  • \$\begingroup\$ The datasheet says: "If the device is configured for 12, 14, or 16 bit-mode, the device outputs two data bytes followed by a configuration byte." (chapter 5.3.3, third paragraph). The documentation of your function mcp3421_read_all says the same. \$\endgroup\$ – Codo Nov 9 '17 at 22:22
When you repeatedly ask for the configuration byte after the data bytes( 2 in the case of 12/14/16bit and 3 in case of 18bit ) the config register is changing. So if your code counts in the last config value acquired you might miss an RDY flag or get a wrong one.
My code did that and it is a bug.
Workaround is asking the correct amount of bytes or the following code.
 * In 12/14/16-bit the middle byte is set to zero.
 * \retval          1           Failed.
    uint32_t err = 0;
    do
            errorHandler();
            return 1;
        /* Get data */
        *config_reg = data[3];//This is config for all data rates.
        if( mcp3421_unmarshal_sample_rate( *config_reg ) == mcp3421_sample_rate_18bit )
            /* 18 bit */
            *upper = data[0];
            *middle = data[1];
            *lower = data[2];
        else
            /* 12/14/16 bit */
            *upper = data[0];
            //*middle = 0;
            *lower = data[1];
            *config_reg = data[2];
            return 0;
        err++;
    while( err<1000 );
    errorHandler();
    return 1;
