So i read alot of data sheets regarding bluetooth modules and when i come acorss antenna section i find that term called effeciency. What is it for ? For example If class 1 bluetooth with 100m range and 70% effiency. It means that effective range is only 70m or what.there is another term called gain is this one has direct relation to range too. Thanks in advance
In broad terms, the efficiency of the antenna is the measure of how efficiently it radiates energy. For example, if an antenna is 50% efficient and we put in 1W of electrical energy, it will radiate (turn into RF radiation) 0.5W of RF energy. Obviously a higher efficiency is good, because it means we get more RF energy.
Antenna gain is a bit more complicated. Basically, different antenna shapes will have different radiation patterns. For example, with a directional antenna, it will radiate a lot of energy in a thin beam in the direction that it's pointing, and not much energy in any other direction. This gain is relative to the radiation pattern of an isotropic antenna, which is a non-directional antenna that radiates equally in all directions. The gain can be measured in different directions from the antenna, but usually when only a single number is given, it refers to the peak gain, i.e. how much better is the antenna at transmitting in a specific direction than an isotropic antenna.
More antenna efficiency is always good, but more gain is only good if you want more directionality. This may not always be the case, for example if you dont know where the other antenna is, you would want power to be radiated more evenly in all directions.
In this case, the manufacturer is quoting a distance for the module and the antenna together, so you can assume that the range is 100m in at least some directions. However, depending on the directionality of the antenna, the range may be lower in other directions. If you removed that antenna and put on an antenna with a higher efficiency, like 100% and the same gain, the range would be 142m (in an ideal situation).
  • \$\begingroup\$ So including the effiency and gain the maximum range will be 100m in ideal situation and less in other direction depending on the radiation pattern correct me if i am wrong \$\endgroup\$ Nov 9, 2017 at 17:28
  • \$\begingroup\$ Yes, although ideal situations are pretty rare, plus manufacturers usually quote the best number that could possibly ever exist (read: lie) \$\endgroup\$
    – BeB00
    Nov 9, 2017 at 17:37
  • \$\begingroup\$ Thank you so much and the last question. There is term called output power of antenna and measured with dbm. Some module contain programmable output power so you can change the value. Does changing this value can affect the range in any mean at least in the 100m example and thank you so much \$\endgroup\$ Nov 9, 2017 at 17:52
  • \$\begingroup\$ Dbm is the output power of the device, its a measure of how many milliwatts the device is pumping into the antenna. A higher dbm means the device is putting out more power, so the antenna will transmit more power, so the transmit range will be higher. If there are multiple power levels, it should specify what power level that 100m range is measured with. If it doesn't specify, it's probably the highest one. \$\endgroup\$
    – BeB00
    Nov 9, 2017 at 20:57
