This load-cell has sensitivity Cn = 2mV/V. In the data sheet the only part about the temperature coefficient is:
How can I calculate the change in sensitivity for a 10°C temperature difference?
  • \$\begingroup\$ If I'm understanding this correctly, dCn = Cn * 0.05% * dT / 10, where dCn is change in sensitivity, and dT is change in temperature in degrees Kelvin. Not entirely sure whether the temperature coefficient is positive or negative (the +/-0.0500 is confusing me there). \$\endgroup\$ – Jim Fischer Nov 11 '17 at 12:31
  • \$\begingroup\$ Thanks a lot for the comment. Now I have a similar problem with interpreting the amplifier: electronics.stackexchange.com/questions/339537/… I would be glad to see your opinion. \$\endgroup\$ – floppy380 Nov 12 '17 at 18:13
