A transformer of primary voltage 220 V and turns ratio of 11:1. The secondary of the transformer is connected to a 30 Ω inductive reluctance in series with a load resistance (R). If the current flowing in (R) must not be below 0.4 A. Then the value of (R) is:
The answer on my book is at most 40 Ω , but I found the answer to be at most 20 Ω
What is did is that , secondary voltage , which can be easily found by the turn ratio, is 20 V
Then, to find the current at the secondary side we divide the secondary voltage = 20 V over the total resistance = 30 + R Ω
after doing the math R should be at most 20Ω for the current at the secondary side not to drop below .4 A
I don't know where is my mistake , Could someone explain to my what I have done wrong on this problem
Well,
\$I >= 0.4 \$
i.e., \$V/Z >= 0.4\$
\$V = 20\$
\$Z =\sqrt{R^2 + X^2}\$, NOT \$(R+X)\$
Solve.
You have added the reluctance and resistance, you can't do that. You have to calculate the impedance of the circuit.
  • \$\begingroup\$ I added them because they have the same unit , why not ? \$\endgroup\$ – user34755 Nov 10 '17 at 16:10
  • \$\begingroup\$ @user34755 Same reason as 5+4i =! 9 \$\endgroup\$ – winny Nov 10 '17 at 16:19
  • \$\begingroup\$ They have the same units, but you know current and voltage have a 90 degree phase relationship in inductor, which is not there in resistor. That phase shift creates this squared relation , when calculating impedance. Refer to the vector diagram of series RL AC circuit. \$\endgroup\$ – Mitu Raj Nov 10 '17 at 16:27
