I have trouble understanding conversion between different data types in VHDL and needed help with conversion to `STD_LOGIC_VECTOR' type in VHDL.
I want the code below to be synthesized such that it can be used on real hardware.
For now i have the code setup as follows
signal   VREF  : real := 65536/3.3;
constant SIG   : real := 2.33;
signal TEMP    : unsigned(15 downto 0);
signal WORD_A : STD_LOGIC_VECTOR(23 downto 0) ;
signal SIG_A  : STD_LOGIC_VECTOR(15 downto 0);
BEGIN
TEMP <= to_unsigned(VREF,16)*to_unsigned(SIG,16);
SIG_A <= STD_LOGIC_VECTOR(TEMP);
WORD_A <= "00110000" & SIG_A;
I used the following libraries : IEEE_NUMERIC_STD.ALL, IEEE.MATH.REAL
I get the following error ERROR: [VRFC 10-1471] type error near VREF ; current type real; expected type natural
Any inputs is appreciated
Thanks
    \$\begingroup\$ You probably want to use the (VHDL-2008) IEEE fixed or floating point packages rather than real, because they are synthesisable. \$\endgroup\$
    – user16324
    Nov 11, 2017 at 0:10
real is not synthesisable in FPGA. You can use:
library ieee
package ieee_fixed_pkg.all
This code compiles :
LIBRARY  ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY TEST IS
END ENTITY TEST;
ARCHITECTURE BEH OF TEST is
  signal   VREF  : real := 65536.0 /3.3;
  signal TEMP    : unsigned(31 DOWNTO 0);
  signal WORD_A : STD_LOGIC_VECTOR(23 DOWNTO 0);
  signal SIG_A  : STD_LOGIC_VECTOR(15 DOWNTO 0);
BEGIN
  TEMP <= to_unsigned(natural(VREF),16)*to_unsigned(natural(SIG),16);
  SIG_A <= STD_LOGIC_VECTOR(TEMP(15 DOWNTO 0));
END ARCHITECTURE BEH;
Note the natural() type cast, because reals cannot be directly converted to unsigned using only basic IEEE libraries.
The "real" type is not synthesisable: you cannot synthesize signals of type real, BUT you can calculate constants using reals and convert them to integers in synthesisable code.
  • \$\begingroup\$ Thanks @TEMLIB The code does compile, but on the testbench fails to run. I am still confused how VHDL datatypes work on real numbers. Wont converting real to integers result in loss of precision? Thanks \$\endgroup\$ Nov 13, 2017 at 15:21
