I've been trying to practice using Matlab for circuit analysis and am trying to create a transfer function plot of a high pass filter where the gain is in volts/volts not in dB.
This is the information I am given:
  • R = 10,
  • C = 0.3e-3, 0.45e-3, and 1e-3
  • w = 0.01:0.1:4000 rad/sec
I've been trying to use the bode() in Matlab returns a transfer function in dB and I was wondering how I could plot it with volts/volt unit and plot all four outputs for each capacitor on the same plot.
  • \$\begingroup\$ Hmm... a bode plot is supposed to plot a dB magnitude plot because that's what a bode plot represents... The only thing I can think of is if you plot your transfer function on an X-Y Axis instead of plotting bode graph. \$\endgroup\$ – KingDuken Nov 11 '17 at 17:33
  • \$\begingroup\$ The bode plot shows you logarithmic behavior, that's why you see dB, because as you know, to convert V/V to dB you have to convert it to 20log(V/V). \$\endgroup\$ – KingDuken Nov 11 '17 at 17:48
